Quad Cortex's I/O Schematic
Covering everything from first start instructions, navigation, and Preset building all the way through to setup examples and advanced MIDI controls. Comprehensive guides to every Quad Cortex feature.
All product names are trademarks of their respective owners, which are in no way associated or affiliated with Neural DSP. These product names, descriptions, and images are provided for the sole purpose of identifying the specific products that were studied during Quad Cortex’s sound model development.
Built using our proprietary biomimetic AI, it can learn and replicate the sonic characteristics of any physical amplifier, cabinet, and overdrive pedal with unprecedented accuracy.
How to diagnose and remove unwanted noise from Quad Cortex.
Quad Cortex can receive CC and PC messages via MIDI DIN or USB.
MIDI Program Change messages for preset navigation.
MIDI Continuous Control messages.
Assign, control, done!
Quick tips and more!
Downloading items from other users to your Quad Cortex unit.
Fixing the most common Wi-Fi connection issues.
International
3-Year Limited Warranty Policy
Three different ways to get your Quad Cortex serial number.
USB Issues, connection stability, etc.
Sending Presets or Neural Captures with a friend.
Using your own IR files is also possible in Quad Cortex.
Saving your data on Cortex Cloud.
Making Presets or Neural Captures available to the public.
Following friends and sharing content.
Lasted updated: February 15th, 2021.
Quad Cortex functions as a USB 2.0, 24-bit, 48kHz (fixed), low-latency audio interface for Windows® and Mac® computers.
CPU management and optimization.
Quad Cortex is capable of sending MIDI messages to external devices.
Quad Cortex is capable of sending and receiving MIDI messages over USB in the same way as via its MIDI Din connectors.
Allows you to visualize what the footswitches are assigned to instantly. This visualization utilizes the entire screen.
Allows you to control the settings of any number of blocks in a rig.
Allows assigning any block in a rig to a footswitch, just like you would with an analog pedalboard.
It enables you to have eight completely different rigs.
Device block dedicated controls.
Save your work easily!
Setlists are Quad Cortex's way of making Presets incredibly easy to use and navigate.
The Quad Cortex's file manager.
We call the screen where you can add blocks to build a virtual rig "The Grid".
Split your signal chain to route your signal to multiple outputs.
