Neural DSP plugins will be installed in default locations for each plugin format unless a different custom location is selected in the process.
macOS®
By default, the plugin files are installed in the following directories:
- AU: Macintosh HD/Library/Audio/Plug-ins/Components
- VST2: Macintosh HD/Library/Audio/Plug-ins/VST
- VST3: Macintosh HD/Library/Audio/Plug-ins/VST3
- AAX: Macintosh HD/Library/Application Support/Avid/Audio/Plug-ins
- Standalone App: Macintosh HD/Applications/Neural DSP
- Preset Files: Macintosh HD/Library/Audio/Presets/Neural DSP
- Settings Files: <User Folder>/Library/Application Support/Neural DSP
- Manual: Macintosh HD/Library/Application Support/Neural DSP
Windows®
- VST2: C:\Program Files\VSTPlugins
- VST3: C:\Program Files\Common Files\VST3
- AAX: C:\Program Files\Common Files\Avid\Audio\Plug-Ins
- Standalone App: C:\Program Files\Neural DSP
- Preset Files: C:\ProgramData\Neural DSP
- Settings Files: C:\Users\<Your profile>\AppData\Roaming\Neural DSP
- Manual: C:\Program Files\Neural DSP
Important: Our macOS plug-ins are available in 64-bit only.
macOS® Library Folders
The Main Library folder is located in the following path location:
- Macintosh HD/Library/
The User Library folder is located in the following path location:
- Open a Finder window.
- Click the "Go" menu at the top bar.
- Hold the "Option" key, The User Library folder will appear in the dropdown menu.
Uninstalling Neural DSP Software
To uninstall Neural DSP software on macOS®, delete the files manually in their respective folders.
On Windows®, Neural DSP software can be uninstalled either from the Control Panel or by selecting the “Remove” option from the setup installer.
