How to install and activate plug-in purchases and free trials.
During the installation process, you will find several packages available to install that you can check/uncheck as you require. Depending on the DAW you use, or whether you use a DAW at all, will determine which of these packages you should use.
All about iLok License Manager software.
Is there any additional features if I purchase after my trial?
Lost activation due to a computer crash or lost USB dongles.
License transfer through iLok License Manager.
Where is everything installed to?
