If Quad Cortex is selected as the main audio device on your computer, you will hear the computer audio through Quad Cortex Outputs 1/2 and Headphones Output. This feature lets you jam along with Youtube™, Spotify®, iTunes®, or your DAW tracks with low latency monitoring.
TRS Outputs 3/4 can also be used for hardware monitoring on macOS:
- Open the Audio MIDI Setup app.
- Click on Quad Cortex.
- Click on Configure Speakers.
- Change the speaker channels "To Out 1" and "To Out 2" to "3" and "4" accordingly.
- Click on "Apply" to save the settings.
Recording Quad Cortex's processed signal, dry input, or specific rows is also possible. In either case, you will hear your signal from Quad Cortex before it's routed through the DAW, which is great for low latency monitoring.
Multiple inputs and outputs can be used by tapping the Input and Output blocks on both sides of The Grid. USB Inputs and USB Outputs are also available here. This feature allows getting different routings without connecting any additional cables to the unit.
Monitoring with both Quad Cortex and a DAW at the same time could cause phase problems. In order to avoid any issues, turn off the input monitoring in your DAW.
I/O Schematic
Quad Cortex features 16 USB channels (8in/8out). Each channel is mapped to a specific source or Quad Cortex’s audio connector. Details below:
HOST USB CHANNEL |
DESCRIPTION |
QUAD CORTEX USB CHANNEL |
Input 1 |
DI signal from analog Inputs 1/2 to host (non-selectable on The Grid). Select Inputs 1/2 on your host to record DI tracks with Quad Cortex. |
Output 1 |
Input 2 |
Output 2 |
Input 3 |
Manual route from The Grid selectable output blocks to the host. Select Inputs 3/4 on your host to route signal from The Grid output. |
Output 3 |
Input 4 |
Output 4 |
Input 5 |
Manual route from The Grid selectable output blocks to the host. Select Inputs 5/6 on your host to route signal from The Grid output. |
USB Output 5 |
Input 6 |
USB Output 6 |
Input 7 |
Manual route from The Grid selectable output blocks to the host. Select Inputs 7/8 on your host to route signal from The Grid output. |
USB Output 7 |
Input 8 |
USB Output 8 |
Output 1 |
Playback from the host through XLR Outputs (non-selectable on The Grid). Select Outputs 1/2 on your host to hear playback through Quad Cortex’s Outputs 1/2 or Headphones Out. |
Input 1 |
Output 2 |
Input 2 |
Output 3 |
Playback from the host through TRS Outputs (non-selectable on The Grid). Select Outputs 3/4 on your host to hear the signal through Quad Cortex’s Outputs 3/4. |
Input 3 |
Output 4 |
Input 4 |
Output 5 |
Manual route from the host to Quad Cortex’s input blocks. Select Outputs 5/6 on your host to route the signal to a row in The Grid. |
USB Input 5 |
Output 6 |
USB Input 6 |
Output 7 |
USB Input 7 |
Output 8 |
USB Input 8 |
